Side Switch Lights Lockout Options?
Do side switch lights with easily pressed momentary type operating switches also need to incorporate a positive mechanical tail switch for positive lockout? It appears to me that such an arrangement, if properly used, would eliminate the risk of lights coming on in the pocket or holster inadvertently without requiring unscrewing a tail cap or battery compartment as many lights do now. I have Olight S10 and S15 Titanium lights and they do not have tail cap lockout capability and even with the side switch electrical lockout activated have come on while being carried. IMO not a good situation.
I would like to see more lights with both a side and tail switch for convenient and positive lock out. I have a FandyFire Darth which has a tail switch and magnetic ring and it can be turned off with the ring and locked out with the tail switch. The same for my Nitecore SRT7 and Jetbeam Premium S2 Titanium made several years ago. If they can do it for magnetic ring controlled lights then why not for electrical momentary side switch lights that require minimal pressure to operate their switches?
I like the side switches but want a truly positive lock out method that does not involve starting to take the light apart which is what lockout via loosening a tail cap is. A switch lock-out which is overcome by holding the switch down for several seconds is not a true lock out to me.
Opinions or other ideas for effective lockout of side switch lights appreciated guys and gals :exmark:
It's nice for that, especially since thread anodization can fail with heavy use and not so great care. The problem is the switch adds a point that could limit high power lights, and even cause them to fail.
Electronic lockout is just as safe, but UI complexity gets to be a big problem when there's only one button. Solution: multiple buttons. I'd like multiple buttons anyway so that there's separate buttons to increase and decrease output that way like control ring lights, output can be changed in the direction you want without cycling through modes in the wrong direction first.
I was thinking of the tail switch being primarily for smaller lights such as are pocket carried or carried in holsters that have the side switch vulnerable to being depressed inadvertently. Hopefully for such lights a tail mechanical switch will nit be too much a problem seeing as how it has been so widely used as the only switch on these lights in the past. Also there are high current switch designs I understand which should stand up to almost any flashlight current level.
That shouldn’t happen. The main current from the battery doesn’t ever pass through a side electronic switch. This is why electronic side switches can be so small and use very thin wires.
The downside is parasitic battery drain, which is not present in a traditional switch where power is completely disconnected.
I think a tailcap lockout is nice to have in a sideswitch light. But I consider it useful more for long-term storage or transport than for EDC use.
The advantages of a sideswitch in a small EDC light:
  • Feels natural in the hand and easy it is to activate. This convenience is completely lost if you have to manually turn the tailcap every time before pressing the sideswitch.
  • Allows for a more compact light than traditional tailcap clickies. Some lights have a tailcap conventional clicky along with an electronic sideswitch. I’m not really a fan of this. If you stick a tailcap clicky on the back of a sideswitch light, then this size reduction is lost.
  • Mechanically more reliable. In theory a sideswitch should be more reliable than a traditional clicky switch because the sideswitch is mechanically much simpler and has fewer moving parts to wear out. A conventional clicky has a small rotating piece inside, usually made from plastic. It works like a pushbutton ballpoint pen rotating each time the light is turned. In contrast, the mechanical portion of an electronic switch is a simple momentary pushbutton that only connects when held down.
I think the best solution is this:
  • Sideswitches aren’t all the same. A big button with a soft touch (such as on the old Zebralight SC51) can easily turn on accidentally. Protruding sideswitches such as in the Olight S series are also more likely to turn on accidentally.
  • In my opinion, the best kind of sideswitch in a pocket EDC light is one that is: (a) deeply recessed, (b) relatively small, and © requires firm pressure to activate. If designed right, the switch should be easy to activate intentionally, but very unlikely to activate accidentally. Enough so that tailcap lockout during everyday use shouldn’t be necessary. A good example of this is the switch in the Zebralight SC600 or SC52 (before they started using softer switches).
  • For long-term storage or when added security against accidental activation is needed, electronic sideswitch lights should have a tailcap lockout. The standard method of anodizing the threads is fine. A tailcap clicky switch isn’t required.
I was talking about a tail switch. Mechanical.
