Wondering if anyone can help me find a new light. I’d like a simple 18650 tube light, nothing bigger, nothing smaller. Just a straight forward tube light, something the size of the Convoy S2+ would be ideal.
Tail switch not side switch.
Single or triple emitter would be fine. Nice tint (circa 5000k) and nice CRI, but not fussed on the emitters really. Its an EDC light, tint is much more important than Peak lumens or lux.
But it must have Anduril 2.
Would be nice if it tail stands, have a deep carry pocket clip and a switch that doesn’t turn on in your pocket.
Does such a light exist?
Over the years… (forget how many, must be somewhere near to 20) I’ve rocked many EDC lights. But my go to lights are still things like the BLF A6 or a converted Convoy S2/S2+ with a BLF A6 driver. They are the most comfortable to carry, 21700 is too big, 14500 runtimes suck! 18650 is the sweet spot. Compact, good outputs and great run time.
I don’t want anything chunky like the Emisar D1, which is great, but chunky in the pocket.
Most lights still seem to have the most dreadful and annoying UI’s, so Anduril 2 is a must, no compromise on this, unless you can find something with the BLF A6 driver in.
I have a Wurkkos TS10, this scaled up to 18650 size would be ideal.
I think what you’re looking for is a Noctigon KR3.
Would recommend also getting a 3-pin UPDI flashing adapter with it, if you don’t already have one. The firmware got a major update just yesterday, and continues to get more updates over time.
I like the NTG 4200K LEDs in it, or Nichia 519A 5700K dedomed. Hank’s custom optic is good too, on par with or better than a Carclo 10511.
Thanks, the KR3 does look good (the FW1A is discontinued though).
With the KR3, does it tail stand?
Also a little concerned about the switch… I’d love it is was a little more recessed like a Convoy S2+
My worry is it activating in my pocket. I carry my EDC in my right jeans pocket, lens down. Most lights are fine, but the Noctigon KR1 switch annoyingly activates when you bump it against something like your coat, waist or whatever. I just couldn’t EDC that light due to the switch, which was a shame, as it was great otherwise, but the crap switch has meant it has spent most of its time on the shelf. I’d hate to spend good money on the KR3 to find it has the same issue.
Prefer a tailswitch, one handed you grab the light and turn it on with your thumb, quick and easy, side switch you have to change grips a bit as you pull the light out. Plus you need to have the switch aligned in your pocket to not squish it.
I don’t mind side switches, have loads, just prefer the tail switch for activation.
Neilsgadgets has the Lumintop FW3A on sale right now. Code FW3A for 30% off. I really like the FW3A host and the tail switch is a little more recessed. Apparently the head and switch are glued on these new releases.
I like the KR3 but I have had the same issue as you with the light being turned on accidentally. A workaround I use is to program Anduril to auto lock after 5-10 minutes. A quick triple tap unlocks it.
Dont have any of these.. but for your needs; i presume these have all the requirements. Accidental activation comes in the package with all these torch; thats what brings holster , locking toggle and lockout mode to the evolution.
Anyway, success with the quest (i believe those torch are good options)
Cheers
That’s a real shame about the KR3, just the sort of thing I was hoping not to hear. It’s also really sad that Hank hasn’t figured this out and ensured his designs don’t suffer such a major problem. It’s not rocket science.
Re: the work around. It’s not for me. It’d drive me nuts having to continually button mash every single time I want to use the light. that sort of thing would instantly consign it being a paperweight. And the entire point here is to try and find a more modern light to EDC, rather than the 10, 15 year+ lights I still end up going back too.
Sometimes it feels like the World is going backwards, rather than learning from past mistakes.
Respectfully I disagree, I literally have shelves full of lights I can EDC without any of them ever accidentally activating in my pocket. It’s all a matter of good design with the switch and how/where it is located.
I carry an EDC for all things, be it sitting at my desk, walking, crawling under old Land Rovers, doing things on the farm. Same carry style and many many lights not a problem here.
Then you get light like the Noctigon KR1, where I only need to walk downstairs or sit at my desk to find is has turned on. Or worse, it has turned on, then somehow activates turbo in your pocket, so you now have a burnt/hot leg and pocket.
We are on the same page. I usually carry lights with McClicky switches simply because I prefer the simplicity. When I do use Anduril it’s in simple mode and no aux. I just need a light with 3-5 levels that doesn’t double as a hand warmer.
Do you mean this one? Looks great, shame it has a 6500k as the only tint option. I have too many lights with a tint like this and for EDC use they just aren’t very nice.
