Simple Defiant 3C Mod
The various posts about this light had peaked my interest but I was doing a decent job avoiding Home Depot until I got a look at O-Ls “Simple and Necessary…” post. The light just looked too easy to mod, I had to check it out so I picked one up last week.
Today I reflowed an XM-L2, T6, 3C from Illumination Supply onto the original star.
While I was there I thought it would be nice to have modes. I had some KD V2 drivers kicking around so I just needed a way to fit the 17mm driver into the 20mm pill. This is what I came up with.
File most of the threads off an empty P60 pill and it can be press fit into the aluminum Defiant pill.
The hardest part was the need for a long spring. The one on the original driver is to large a diameter for the V2 driver and the V2 driver is to short. I had one laying around that would work so life was good.
I won’t go into detail about my hour long attempt at adding some copper to the underside of the heat sink. I’ll just say that after carefull consideration I decided the aluminum would be fine.
This is what it looks like now, a little bit ugly but functional.
I set the driver to 2 modes, Hi, Med without memory. I thought about adding a few 7135s but didn’t think the switch would handle the extra current. I don’t think it would have made that much of a difference anyway.
Before the mod I measured just under 2.0A with the batteries that came with the light. Now I get just under 2.5A on high and 0.8 on medium with the same batteries. I’m going to get some NiMH C cells and see how it does.
I like the tint much more.
Original XM-L
XM-L2 on high
XM-L2 on medium
Sorry for my lack of beamshot skill, I still haven’t figured it out. The white balance was set to “Daylight” and the wall is white so the tint comparison is pretty good.
That's a pretty good idea with the P60 in there. Looks good to me.
Sure is a big difference in tint.
I have mod’ed a few of these. I just strip the two parts off the original “driver” and use it as a contact plate. A 17mm driver fits in the pill cavity just fine. I wire it to the contact plate with silicone wiring. I also line the wall of the pill cavity with Kapton tape as an insulator (you could use just about anything, including paper).
