I bought a couple of crappy power bank (the one from BIC and another $2 power bank) and they have at least two issue:
- No overcharge control
No over discharge control
So I search on the forum and I found this thread with a lot of info BUT not the answer I was looking for.
All the suggestion are for dual bay mobile power bank but I need the single bay version and all the experiences are negative.
So, is there a good single bay (small) mobile power bank??
Thanks for the help!
Sorry for being off topic, but that is scary that the tobacco companies can check and see if your SSN matches your name that quickly. I’m no conspiracy theorist, but that is freaky!
FASTTECH has a bunch of them on there. Just because HKJ hasn’t reviewed ALL of them doesn’t mean they are all bad. I really like the look of the Ruinovo 3 battery pack
Yeah…unfortunately it will hang up…I tried this, taped a 18650 in my Miller ML-102, charge the battery, but when I tried to charge something, I had to remove the battery and put it back in for it to be able to charge…if they had a reset button or something to temporarily sever connection to the battery to activate the charge, other than that…they work freeking GREAT! I replaced the charge resistor on my V6.0 ML-102 w/ a 2.2K ohm resistor for approx 500mA charge current to the 18650…yeah it takes a bit longer to charge but it doesn’t stress the battery as much
