There's been a bit more chitchat here than expected. Interesting…
Problem here is fusing beams from emitter dies with are inevitably apart. I believe this can be sort of done to some extent, but the reflector must somehow be located off-focus (a little bit higher maybe) and the emitters should be placed making a sort of perfect geometric shape from the focus center. Like all 3 emitters at 60° from each other (isosceles triangle) and 60° rotated from each other (there would be an isosceles triangle hole right at the center).
Cheers
