I tried boring out the narrow optic in order to test/practice my technique. I tried using a tapered wood dowel chucked into a battery powered hand drill, with damp, loose silicone carbide grip.
It opened up the bore a bit, but I ended up grinding down the optic, shortening its length at about 2x the rate I was opening the bore, so that’s a fail. I may order a few more to learn on. I think I’m going to try gluing some fine sandpaper to a tapered dowel next.
