SK68 mod best yet.
Ok, so I have been messing around a bunch with these SK68’s and I have tried a few different ways of modding them including XML’s with dome and without.
Direct drive XP-G2 de-domed is simply amazing. No Ring at all, perfect round flood very bright nice neutral color and it throws when focused out like you wouldn’t believe.
For anyone who hasn’t done this it’s well worth it. Even if you don’t want to get rid of the modes I’m sure it’s still worth it.
Simple directions.
Soak XP-G2 in gasoline for a couple hours or until the dome fall off. I just take a pair of needle nosed pliers pick it up and tap the emitter (not the dome) and the dome falls off then I rinse under water. Then simply un-solder the old one and put the new one in it’s place. If you want to direct drive just un-solder the negative and solder it to the outer band of the driver. (the little gold colored spot right around the edge)
Seriously super easy and it’s a huge improvement for next to nothing.
What is the difference between the G2 de-domed and the SK68 with a de-domed xml
Sounds like I have to add an xp-g2 to my next fasttech order. :slight_smile:
I like the sk68. It’s so simple and cheap and yet so nice.
How works direct drive out for the switch? It looks somewhat fragile.
Have to try it out with an li-ion cell some time. I gues the output with the original emitter will then be compareable to my saik sa-9.
The de-domed XML doesn’t throw as far but has a much bigger square when you do and in flood mode is bigger but still no ring which is nice. I really can’t stand the ring, it just drives me bonkers.
No problem with the switch on mine but I don’t know what they are all like. This is one of the UltraOK ZS-2 ones. That a bunch of us bought a while back for $2.50 each.
Cheers for that, got a couple of de-domed xmls doing nothing will give this a try.
I really love the XPG2 in the SK68 (mine is 3 mode alum mount between 7 and 8W on high using a TF14500).
How many watts are you getting for max draw on direct? When freshly charged, what are the current, volts, and battery used?
I guess practical max watts is about 10W on copper based on Match’s data, assuming the heat sinking/dispersion can be improved enough.
Hope somebody can come up with lux and throw info for the XPG2 in an SK68 with and without dome.
I have no way to test it, my MM is bi-polar. It basically tells me if stuff is working or not and that’s it. For instance a fully charged 18650 reads 4.39 and my most powerful single cell light is just over 1amp.
I need to pick up a good one and a good lux meter too. But I keep buying emitters and drivers and new lights instead.
I use a TF 14500 as well the grey ones though.
