My Skilhunt h02 was not as waterproof as I hoped. It got exposed to salt water and leaked through the lens. There is a O-ring between the lens and body, but in my case the o-ring is too thin, it does not provide almost any pressure when the lens cover is screwed in.
As a result, I need a new emitter and driver. I have never done this kind of mod before, so could someone recommend good and cheap set. I’d be happiest with lo-mid-hi type of driver and neutral-white or a bit warmer emitter (i use the light in mechanical work, it is good to see colors clearly).
You can use a Nichia 16mm or XML2 16mm emitter. There is a double stacked driver inside the light itself. You’ll need to retain the contact board, that the battery touches but swap out the actual driver inside the light. You can solder the new driver to this contact board. So you take say a 17mm driver, from mtn. electronics… you’ll need one made for an electronic switch. I soldered the spring on this new driver to the center spot on the contact board in the H02… then run a small wire from the outer ring of the driver to the outer ring of the contact board. This has worked well with mine. Then there are the two leads for the e-switch. One goes to the ground on the driver, and the other goes to the spot on the driver, say star 3 or 4 and then it’s a go.
You may need to grind the emitter a bit where the screws go, because I found the two screws holding in the emitter didn’t quite line up with the Noctigons spaces for screws that I used.
thanks, so you cleared all the components away from the original driver? anyway, it sounds like a lot of work, isn’t there any drivers that would just fit in as they are?
do you have any recommendations for the emitter? should the original have been connected with screws? mine didn’t have any, although there were holes for screws.
