In general, the higher the CRI, the lower the blue wavelength because the phosphor needs to convert more blue wavelength into other wavelengths to achieve the high CRI. Of course lower CCT means lower blue light because more blue light needs to be converted in order to achieve the lower CCT. But you never know unless you test them. You can compare the blue peaks in the ones I tested.
