Thanks Joshk.
Which parameter is relevant for blue light level? I guess that low CCT and an even spectrum mean low blue light but is there a more direct measure of it? Do you have a definition of the blue peak value and typical values for incandescent bulb, for example. Google didn’t help me with that.
In general, the higher the CRI, the lower the blue wavelength because the phosphor needs to convert more blue wavelength into other wavelengths to achieve the high CRI. Of course lower CCT means lower blue light because more blue light needs to be converted in order to achieve the lower CCT. But you never know unless you test them. You can compare the blue peaks in the ones I tested.
The 460nm “blue peak” of a 2700k LED bulb is about 1000x LESS than the sun at noon today. “blue fear” mostly comes from shady salesmen and click-bait writers.
To better quantify what I am saying, The sun is putting out 2000mw/m2 of 460nm blue light right now. My 2700k LED bulbs put out 2mw/m2. My meter was in relative mode back when I was testing cool-white bulbs, so I don’t know the numbers for them right now. Factory defaults… :weary:
Thanks for the answers. Just to be sure - is it true that whenever the blue peak is low and the spectrum is similar to incandescent light there will be not much UV? So there’s no need for getting a separate UV measure?
Yea a quality 2700k LED bulb will look incredibly similar to a 2700k incandescent to your eye. The meter will know the difference though. LEDs get away with the difference so well because our sensitivity to light drops off bad out where the LEDs drop off. Honestly, I think we (humanity) has the tech to fill the graph a lot better, it’s just not worth the extra power and heat to do so.
2660k Incandescent bulb:
2600k LED bulb:
There are some specialty LEDs that use a UV emitter (I think user Sunlike sells one), but I have never seen a second seller of them.
I ordered a new batch of Auxmer (formerly Auxma) LED strips to test. My all time favorite was their 2400k. Seems the quality haven't changed after two or more years. They recently released the 2200k, which is also amazing. The 2000k is like candle light and perfect for the bedroom as it produces negligible amount of blue light, which means it is the best for sleep.
Auxmer 120LEDs/m LED Strip, CRI95 DC12V/24V, 28.8W/m 2000K 2007K -0.0009 DUV 95.3 CRI Blue light relative amplitude 0.07 94.5 R9 94.1 R12 92 Rf 106 Rg https://www.aliexpress.com/item/32948777264.html?spm=a2g0s.9042311.0.0.54fe4c4dn4hG5Y
Auxmer 120LEDs/m LED Strip, CRI95 DC12V/24V, 28.8W/m 2200K 2109K -0.0024 DUV 94.5 CRI Blue light relative amplitude 0.12 90.3 R9 81.9 R12 93 Rf 104 Rg https://www.aliexpress.com/item/32948777264.html?spm=a2g0s.9042311.0.0.54fe4c4dn4hG5Y
Auxmer 120LEDs/m LED Strip, CRI95 DC12V/24V, 28.8W/m 2400K 2340K -0.0049 DUV 95.0 CRI Blue light relative amplitude 0.22 97.8 R9 88.2 R12 91 Rf 108 Rg https://www.aliexpress.com/item/32948777264.html?spm=a2g0s.9042311.0.0.54fe4c4dn4hG5Y
Auxmer 120LEDs/m LED Strip, CRI95 DC12V/24V, 28.8W/m 2700K 2505K -0.0018 DUV 96.5 CRI Blue light relative amplitude 0.24 94.6 R9 88.5 R12 94 Rf 102 Rg https://www.aliexpress.com/item/32948777264.html?spm=a2g0s.9042311.0.0.54fe4c4dn4hG5Y
Auxmer 120LEDs/m LED Strip, CRI95 DC12V/24V, 28.8W/m 3000K 2955K -0.0023 DUV 96.0 CRI Blue light relative amplitude 0.41 88.7 R9 90.7 R12 95 Rf 101 Rg https://www.aliexpress.com/item/32948777264.html?spm=a2g0s.9042311.0.0.54fe4c4dn4hG5Y
Thanks so much for these tests! I recently had my first experience with E17As in 2000K and I’m hooked. Never really ventured below 3000K before. I’m liking the look of the 2000 and 2400s… Also going to try and replace some kitchen cabinet lighting with some ~3500K strips. Anything in that range you have experience with?
Sorry I haven’t tried 3500K. I’m using 3000K for my kitchen cabinet strips. Looks pretty white actually especially at night time when the other lights are about 2700k and under. Incandescent is about 2700k
Mine are currently in the ~3300K range and look really nice. I wouldn’t mind I don’t have a super accurate way of measuring CCT though, just my calibrated eyeball. The other way I do it is with a sheet of copy paper and my cell phone camera in manual mode where it will display CCT. Who knows how accurate that is, either.
Thanks for the tests! Curious about the 2000K, as I don’t see them as an option when I follow your links, but I have a sunset/sunrise simulation project on my list, and it sounds like they’d be perfect.
Edit: Also, did you test the 19 or 28W variation? And in either case, did you find the 95lm/W accurate?
Please see post 47. It includes the 2000K and all of them are the 28.8W version. I do not have a way to test lumens for led strips. They are damn bright though but over time the brightness decreases noticeably due to the heat. These need to be adhered to aluminum channels to dissipate heat. However, I have these adhered to wood which does not dissipate heat. You can get a lower power variant to better preserve brightness and longevity of the LED
I’m referencing post 47 - the link you included for the 2000K takes me to a product page that doesn’t include a 2000K listing. Unless the “Amber” option is 2000K?
You need to contact the seller for the 2000K version. It is not listed.
Oh okay, thanks for the info! Thanks to that and your test results, I think I’ve settled on the 2000K for the end of my nightly sunset :sunglasses:
Keep in mind 2000k is an acquired taste. The first time I turned on 2000k in the daytime, I didn’t like it thinking it was too orange. Half a year later I used it at night time and after my eyes adjust to the color temp (takes about 10-20 minutes), it doesn’t appear orange anymore and colors really pop out due to the high Rf and Rg values. Now I really love 2000k for bedtime use or when I need to preserve night time vision.
Auxmer 120LEDs/m LED Strip, CRI95 DC12V/24V, 28.8W/m 2000K 2007K -0.0009 DUV 95.3 CRI Blue light relative amplitude 0.07 R9: 94.5 R12: 94.1 92 Rf 106 Rg 2000K link
Auxmer 120LEDs/m LED Strip, CRI95 DC12V/24V, 28.8W/m 2200K 2109K -0.0024 DUV 94.5 CRI Blue light relative amplitude 0.12 R9: 90.3 R12: 81.9 93 Rf 104 Rg 2200K link
Auxmer 120LEDs/m LED Strip, CRI95 DC12V/24V, 28.8W/m 2400K 2340K -0.0049 DUV 95.0 CRI Blue light relative amplitude 0.22 R9: 97.8 R12: 88.2 91 Rf 108 Rg 2400K link
Auxmer 120LEDs/m LED Strip, CRI95 DC12V/24V, 28.8W/m 2700K 2505K -0.0018 DUV 96.5 CRI Blue light relative amplitude 0.24 R9: 94.6 R12: 88.5 94 Rf 102 Rg 2700K link
Auxmer 120LEDs/m LED Strip, CRI95 DC12V/24V, 28.8W/m 3000K 2955K -0.0023 DUV 96.0 CRI Blue light relative amplitude 0.41 R9: 88.7 R12: 90.7 95 Rf 101 Rg 3000K link
Made some adjustments to the above table by SKV89, namely for it to be considerably less wide. Helps quite a bit when viewing this thread page on mobile. It may still be good if some column widths are fine tuned, can't do it myself with ease now because (as usual) I'm on my smartphone.
However, for this to have any practical effect SKV89 needs to edit his above table and apply the changes, or copy and paste this one.
Received the Gree Lamps 2000k 5M 600 Led strip reel,weight 70 grams but every meter of the strip is welded.
Seller is able to report Spectrum test di requested
These https://www.aliexpress.com/item/4000513067134.html?
have thicker copper pcb,120 grams for 5 meters but also thicker glue that is 1mm.
Maybe not the best to transfer heat away.
Cheap and interesting their double CCT strips 120 or 240 Leds/meter
I don’t see 2000k. Do you mean 3000k? Sometimes the manufacturer’s report is not accurate.
The site is a bit confuse with many list,this Is the 2000k 12V bought 11$ with coupon
https://www.aliexpress.com/item/32847232453.html
How much Is weight of auxmer 2835 120LED/m 9.6w/m?There are weight difference compared newer 28.8w?
