SkyRay King mod idea
Ok, bear with me this is just a "brainstorming" idea
I bought one of the "new generation" SkyRay Kings, the ones with the el-cheapo driver without the very large spheroid coil drivers
OLD Driver
http://i.imgur.com/fqTKU.jpg
NEW driver
http://imageshack.com/a/img853/5756/tqsa.jpg
I notice between the driver assembly and the led plate there is about 1/2" of space (where the old coils used to sit)
Since the batteries are in parallel in the battery tube, and the fact they have small 1A Li Ion charger pcb's based upon the TP4056, I am thinking I can fit one of these in there and wire in the outputs to the positive and negative (before the switch, not after) and then find a bulkhead port and be able to have an external charging option without having to open up the entire shebang to charge the batteries, I know it's possible to safely charge 4 cells as long as they are in parallel (in effect making all of them one large cell and they stay equalized and matched electrically [unless one goes bad])
Any suggestions on a bulkhead or panel mount usb or micro-usb fitting that can be put in to facilitate this?
