SkyRay King... which one is genuine? And is it important?
I’m sure this has been asked many times before, but I couldn’t find a definitive answer.
With all the versions of the SRK (from CNQG/FF, Manafont, Tmart, DX, FocalPrice, Wallbuys, FastTech, eBay sellers) - which companies sell genuine SRKs?
What is the “three torroids driver” and why is it better than the other driver (if at all)?
And does this even matter what type of SRK / FandyFire flashlight I buy, as long as it is 3xXML U2 and 4x18650? Will the non-genuine just produce less light? (I read somewhere some are brighter than the originals, I think) Have worse heat management? Have button issues? Use series instead of parallel battery configuration? Explode?
CNQG/FF and maybe Manafont and FastTech too. Tmart and DX are known to sold fake SRKs.
This one. It's better because it's regulated.
Usually yes (It can be anything from 1100 to 2300 lumens).
Is the driver shape a definitive way to tell if it’s a fake or not?
No, many fakes use same drivers (or at least same looking driver boards).
Just get the one from FF/CNQG/FastTech.
The one's from FF/CNQG are definitely the real deal, haven't gotten one from FastTech yet, but the tonne of stuff that's already arrived for me has all been legit.
FastTech's probs the cheapest around (less than 40 bucks with the BLF coupon!) but they don't have Neutral White, if that's what tickles your fancy.
EDIT: link to FancyFlashlights SRK - no shipping charge. Black NW-only here.
SRK @ FastTech (CW only) - free shipping, choose colour from drop-down menu.
The one I just received from wallbuys appears authentic. The output and amperage draw are identical to another one I have that I confirmed to contain the 3 terroid driver (which is the higher output of the two being offered).
That’s good to know, especially considering their current price.
Could you open the flashlight head to verify this? Or is it too complicated? (e.g. need to desolder leads)
btw, the ~200 extra lumens (optimistic) of the U2 version aren’t a deal breaker here, right?
I mean, it’s only about 8% max difference, not really noticeable, or is it?
The driver is glued in. To get the other driver out of a different SRK, I had to remove the power button, then push the driver through the hole the power button came out of while using considerable force with a long dental pick. Since the hole is blind, there is no way to see where I was applying pressure to the driver and I risked damaging or destroying it. So no, Im not going to risk my new SRK by doing that again.
From reading many other posts regarding the “mimic srk” Im convinced that mine is authentic or at least is driven as hard as the original (2A per emitter). The mimic is quite noticeably less bright and draws less amps from the batteries and does not have a 3 terroid driver. Having said that, there appears to be at least 5 or 6 SRK versions floating around, all of which have variations - which makes the term “original” meaningless.
In all likelihood, your eyes will not be able to detect the difference between T6 and U2 in the SRK. I will say that the tint in the wallbuys SRK is very white but not cool or cold.
What is it youre trying to do with your SRK? Maybe others can chime in as well…
Sounds like I’ll join the Wallbuys deal…
(and definitely don’t destroy a good flashlight for this, if it works and you enjoy it :slight_smile: )
Its good to have you with the other +150 others. Im sure you’ll enjoy it.
FLASHLIGHTPILOT or owners of the wallbuys light.
Is that light using T6 cool white LEDS?
I assume it is not warm or neutral as the sales text partially indicates.
In the example I just received, yes.
Ok, thanks!
