SkyRc Imax B6 Mini Charger Set Up
I have the SkyRc Imax B6 Mini charger set up the same as the Reaktor 250 Watt. This charger is a 60 watt and I use the same charging cradle and power with it that I use with the Reaktor 250 watt. This is a very nice little charger that does it all. The charging options you have are very handy and it analyzes the batteries as well, i.e. Internal Resistance.
Check out all it’s functions.
SkyRc B6 Mini Link]http://www.skyrc.com/index.php?route=produ…;product_id=200
I bought mine here and it checked out as Authentic on the SkyRc web site.
Purchase Link]Amazon.com
SkyRc Imax B6 Mini 60 Watt charger
Reaktor 250 watt set up for comparison.
Bill
That’s pretty cool!
Balance charging and everything…awesome
Nice setup :)
The circuit board I had FAR Circuits make for me made it easy to set up. The board connects all the cells in series via the cell holder. Solder the holder and wires in place on the board and your good to go.
Bill
Nice! I had a similar setup before but I had to manually change the end leads when charging less than 4 cell in series, after some time I found normal chargers more convenient for everyday use…
