Small AA boost drivers and low Vf leds
I'm wanting to use a small 15mm boost driver commonly found in your sk98's and so on, like the Nanjg 103 driver. I am wondering if it will always boost to a higher vf like that of an xp-g/xp-e/xm-l or will boost to whatever current the led requires. I want to use a low vf red led in a sipik clone with an eneloop AA battery, but don't know if it will boost it to the 2.2-2.5 range the red led requires, or if it automatically boosts to the over 3v range of white leds? The one I'm using came in the host and looks like every other boost driver out there except it has an R300 resistor where most other's ive seen have r200~ish or an R100 in this one (although its 17mm)
https://www.fasttech.com/products/1612/10001750/1127402-12-aaaaa-1-mode-800ma-linear-booster-led-flashligh
The one I've got looks a lot like this one from KD:
http://www.kaidomain.com/p/S024884.15mm-0_9V-3_6V-3-Mode-Boost-Driver-Circuit-Board
I also plan to stack an r250 on there for hopefully well tolerated current increase, and pencil-lead the cap to help with the ridiculous strobe, but that's another story.
Any thoughts on how these boost drivers react with lower forward voltage than they were probably designed to be use with?
With one AA it will be fine for a red LED.
The LED determines what the output voltage will be.
It may push a little more current than with a high Vf (white or blue) LED though.
