I just put together one of these with a qlite driver and an xml2 led. The driver peaks at 1900 ma. It is quite bright and although not a thrower still lights things up for a ways.
The light is compact and nice to carry and even driven at about 500 ma it puts out quite a bit of light. That should give decent battery life.
The qlite has moonlight mode however it is still fairly bright - not a lot of difference between it and the low mode. I haven’t looked into this but there is likely a solution.
I was tempted to put a xpg2 in it but the opening in the reflector was quite big (fit the xml2 well) and I wasn’t sure how that would impact the beam.
Mountain electronics was were I obtained the driver, led and host - very good service if you need the goods.
Mtn Electronics triple XP-G2 Convoy S3. The moonlight mode isn't very low though. It's more like a very good low. Richard (RMM) can build you one for around $60.
Any of the convoy s series would be good.
I just built myself an xp-g triple in an s2 this morning. I haven’t bridged the star on the nanjg for moonlight mode on mine, but it is an option.
Got most of my parts from mtn electronics (RMM), or you can buy one prebuilt.
My usual light for camping and edc is a solarforce l2m, but that has a bit wider head.
Is a C8 too big?
It throws very good and gives lot of light and on Banggood you can choose tint and reflector style(xml2 4c SMO is a neutral white smooth reflector version) all for small money…
The convoy S are very nice but even with a dedomed XML they don’t throw so I guess a xpg isn’t much better. The M1 is better but I wouldn’t call this a thrower either but it’s better than the S types.
S2 host you will need a driver and a xpg. A nanjg with 8 chips and 2.8A gets hot fast in these small hosts maybe you should go with the 2.1A Version
On both sites you can use the coupon code BLF for some additional discount
For camping I’d recommend either a 502B from Mtnelectronics with a p60 loaded with an XP-G2 or Nichia 219 run at 1.5-2A with a Qlite driver or a Convoy S2 with the same set up. A diffuser cap might come in handy for area lighting. Neither host is capable of high currents for extended periods and the stock 1.4A driver he sells is adequate for this. If you want to run at slightly higher current go with the Convoy M1. It has a bigger pill/more fin area and slightly larger and deeper reflector than the S2 or 502B but is still has a smaller head than the C8.
Why not get a headlamp instead, crelant ch10 can ramp down to moonlight, throws pretty good, and a headlamp frees your hands, and is pretty cheap. I think you can get it with either emitter
