Sn96.5 Ag3 Cu0.5 Solder Wire
Hi All,
My spool of solder wire is about to run out so I have been looking into what alternatives are available and in particular the lead free types as I do a fair bit of soldering these days and don’t have any form of extraction or fan set up to remove the fumes. I currently use 0.6mm SN63 Pb37 rosin core solder and it has been good. I prefer the 63/37 solder over the 60/40 because of its instant transition from liquid to solid.
Anyway, I found some 0.6mm Kester wire which is Tin/Silver/Copper composition with a 66 size flux core (3.3% flux by weight) and a “no clean” type flux.
Have any of you had any experience with this type of solder? How does it compare to the traditional 63/37 wire? The price is irrelevant, I’m just after a high quality solder wire that is easy to work with and it would be nice to get a lead free one.
Thanks in advance!
Here's a PDF file right from Kester. That might help. I never use lead free, so I can't do much, but google helps.
One comment from experience —- you’ll want that extraction fan (maybe with a carbon filter) set up anyhow.
Computer box fans cost $2-3, and a run of 4” aluminum dryer vent costs a few more dolllars. A window flap, maybe $6.
Lead dust is a longterm (as in permanent) dust problem, that stays the same wherever it goes.
Flux outgassing/vapor/products are a short term immediate annoyance — the nasty stuff is mostly neutralized when it reacts with something organic (mucous membrane, eyes, lungs) —- but they are sensitizers, like darkroom or biology lab chemicals. You can work around them for years with only annoyance, and suddenly find you’ve developed a severe ongoing allergic reaction to anything related. That’ll screw you up in multiple ways for years, maybe the rest of your life.
That thing about “anything that doesn’t kill me makes me stronger”? It’s a lie, sometimes.
