So, I want to control a DC fan, (like a fan for a PC), with a thermostat, what do you think of something like this?
I just need to determine 40C. 45C or 50C for cut in, to turn on the fan.
EDIT: 3-3-14
So, I am playing with fan cooling. Of course it would need to be on a bigger light, with room for a fan, but what about waterproof? Well, if the fan was the only thing exposed to any moisture, then it might be waterproofed, good enough at least to take exposure to some water, like out in a rain shower. So, I am playing around with an old fan I had lying around.
I cut the fan out of the housing and maybe I can seal up the circuit board, so water won't get to it. Maybe...
I have already removed the plastic washer from the shaft, so I can take off the blades.
I used regular silicone. I could have used fujik, but I figure just for a test, this ought to work. I have sealed just around the area where the circuit board is, so water doesn't get to it. I'm not really worried about the stator wire wraps. I shouldn't need to seal it.
Once all this dries, I will put the fan back together and toss it into a bucket of water, with some batteries to power it up. If it works, I will have a plan to use, for some active cooling. If I use a 40mmx10mm fan, it might put out about 5cfm. If I go with w 40mmx20mm fan, it might get up to 8cfm. Ok, that's not a lot of air flow, but how much air flow is inside a regular flashlight? Zero, zip, nada, so a few cfm is better than nothing, isn't it.
So, I got the fan back together and I tested it.
I just hung it in water and left it hang, while I checked to see if it was getting any continuity across wires, which it never did, so here goes.
Works fine and I even left it in water for a half an hour or so. Good enough for me. Now I know I can seal a fan and now I can use a fan in a build. It's all I needed to know. When I do it for real, I will use Fujik most likely.
