I mistakenly bought these SKU: 88010638 from tmart thinking they were lion batterys but it turns out they are lifepo4. My only charger is a nitecore i4. Is there a way to charge them with the i4 or am I screwed. They are protected, will they stop charging when they reach the max or is that too much voltage ? The thing that is misleading is they are advertised as being lion
These cells are not protected! Stop charging at 3.65 volts or you’ll damage the cells.
I have 8 of them myself and they are just right for flashlights, that run way too hot on normal LiIon cells,
for example the Balder HD-1.
I have a few of those also, but don’t charge them with the i4. You’ll need a charger that supports LiFePO4, or if you have a hobby charger, those can be used also. Sorry about that…
Here is the manufacturer site: http://www.soshine.com.cn/a33.aspx
They are not protected, stop charging at around 3.6V and stop discharging at around 2.5V.
You can run them down more without destroying them, but life will be shortened.
I use this cheap charger from the bay: http://www.ebay.com/itm/260862907077
The charger is ok, the cells are more mediocre at ~400mAh though.
