Ya, I have 3-extra KingKong’s and 2-TrustFire’s 26650’s I know that sucks about them not fitting in my K40 either I called Jason about that and he said he mentioned that to the factory. The only ones that will fit in it is Xtar 3100. I have no problems putting them in my TN31.
My Shadow SL3 arrived yesterday from sbflashlights
It’s my first triple Led light, except for a P60 triple xp-e that i just sold. That used an optic though, so doesn’t compare to the SL3.
I ordered the Shadow 18650 sleeve along with the light, and i’m really impressed with both. The o’rings on the sleeve do a good job at stopping rattle.
The SL3 is very solid, with some weight to the head, and the side switch has a nice positive feel.
I really like the beam the SL3 produces. It has a very concentrated hot spot that throws really well, and the spill is plenty bright enough to light a large area in front of you.
I have compared the SL3 with a 4.5A P60 XM-L i have. They both look roughly as bright as each other shining out into the garden, but the SL3 has a much brighter hotspot, and wider spill, although the p60’s spill is brighter.
So far i have only used Panasonic cgr18650ch cells in the SL3. I have a couple of MNKE 26650’s on the way.
I let the light run for a few minutes(i wasn’t timing), until it stepped down to the reduced level. Switching the light off then on again re-activates full brightness for another few minutes. I managed this a few times until the cell was nearly depleted.
I’m happy with the SL3, and think its well worth the asking price :bigsmile:
Cheers
Matt
EDIT: once the SL3 has stepped down from high, simply cycling through the modes and returning to high gets you to maximum brightness without needing to switch the light off.
The light does get warm/hot though if you put it back to max brightness straight away.
