【SOFIRN HS22 New released】The SOFIRN's 1st Adjustable CCT (3000K to 6500K) Headlamp new demo updated 2025.6.9
Hello BLFers,
I noticed SOFIRN Official web has started updating SOFIRN HS22 new link(https://www.sofirnlight.com/products/sofirn-hs22-headlamp-2500-lumens-ultra-bright-headlight?st=).
Let me ask SOFIRN factory the specific time and budget discount right now ; )
2025-6-10 updated
We updated the HS22 new features detail demo now.
2025-6-9 updated
What do you think of the SOFIRN’s 1st Adjustable Color Temperature Lightweight Headlamp?
[:sunrise:]3000K-6500K Stepless Tint Adjustment
[:flashlight:]2500 Lumens Ultra-Brightness
[:sweat_drops:]3 Output Modes (Spotlight, Floodlight, Hybrid Beam)
[:battery:]4000mAh 18650 Li-on Battery
[:triangular_ruler:]180° Adjustable Angle Headband
We post the beam shot demo here now. Hope you will enjoy it :wink:
Looks interesting, but what emitters are being utilized? What’s the CRI? Is it a FET, buck, boost, or linear driver? Does this have USB-C charging?
Yep, looks interesting.
I have some questions, too.
Is the throwy emitter paired with a traditional reflector or a TIR?
Is the 4000mAh 18650 a regular Li-Ion cell that can be replaced with another run-of-the-mill 18650?
Looks nice. What is the UI like? Two button UI like the HS20?
What LEDs does it use? 519A and SFT40?
The LED on the right also changes CCT, so it has to be something else.
I hope for 3535 on the left and 5050 or 7070 on the right and a case that can be disassembled… Sofirn, please listen, especially the last part is important. Glue and flashlights should not mix, ever!
OK, weird.
THe VIdeo clearly shows the thrower LED changing color…
I love the innovation, especially the design from the standard cylindrical that most companies have.
This is a CGI video. Apparently author found it too hard to arrange two light sources.
I find it hard to call this “innovation” when the “moonlight” mode is a blasting 5 lumens
Lightweight only 1KG ! :grin:
This does not look like anyone can get into this light without breaking something?
Just modded the HS20 minutes ago, screwed down bezel - this looks like a clipped-in optics that cannot be removed?
Sofirn seems to do everything to not sell me a flashlight anymore.
Dang! That would be destroy every headband :joy:
Thanks for your support. The emitter spot is SFT25R. Flood is Lattice power TN-3535 4, 6000K2 for CRI 70+, 3000K*2 for CRI 90+. Buck driver it is. Equipped with USB-C charging.
Thanks for questions. The throwy optics is TIR. We found a great 18650 regular Li-Ion cell supplier now. They can provide 4000mAh battery with worth price. Also, the HS22 could be replaced with another run-of-the-mill 18650
Yep, you’re right. The UI like HS20. Also, the LEDs use the spot SFT25R and flood latticepower TN3535
Throw light cannot change color. Sorry for wrong Optical Demo. Here is the color change caused by the diffusion of lens light when rendering animation.
Thanks a lot for your support always ; )
When will it be on sale?
