Sofirn SC18 / Wurkkos WK 03 vs Convoy S2+
I own all 3 of these lights. The SC18 and WK03 are 100% identical except for the texturing on the body tube. I suspect they’re made in the same factory.
Comparing the SC18/WK03 to the Convoy S2+
Pros of the SC18/WK03
  • Significantly Smaller
  • Onboard charging
  • Side side switch.
  • Electronic switch allows for a more intuitive interface.
  • It may be brighter than the Convoy
Pros of the Convoy S2+:
  • Tailcap clicky switch is unlikely to accidentally turn-on in the pocket. Unlike the protruding rubber button on the SC18/WK03, which might require use of electronic lockout.
  • No parasitic drain
  • Many more choices of emitter
  • More heavily built, so probably more durable.
  • No rubber charging port cover to get damaged.
  • If you get one with metal switch, then there are no expose rubber parts at all to get damaged.
If I had to choose only one of these lights I’d choose the SC18/WK03. In my opinion, the Convoy is just too big for pocket EDC.
