Hellie112
(Hellie112)
41
Just received two SF13 “420 lm version” (ordered during the spring sale for giving away to friends). And I can report that the bezels on these two units aren’t glued.
SKV89
(SKV89)
42
Bezels arent glued. I modded three of them last week with e21A 9080 and Optisolis. Works well except I dont like the UI as much as the SF14
As far as I know, there’s no short cut to low. The light always uses mode memory.
The manual’s not very good, shall we say. Just as an example, the German part of my manual actually refers to a completely different light!
Which PCB are you using for those mods? Is that for both the SF13 and SF14?
What are you using for an optic/reflector, and does it work reasonably well with the Optisolis?
If you’ve come up with a good combo, this seems like a cost-effective way to get rare emitters into practical lights.
SKV89
(SKV89)
45
16mm vr16 mcpcb from virence.com. I buy them presoldered. It fits the sf13 and sf14 v1 but does not fit the sf14 v2 because they decreased the mcpcb to I think 15 or 14 cm. Too bad the sf14 v1 not available anymore.
hank
(hank)
46
I’m curious where the difference arises between the second 420 lumen version, and the first SF13 320 lumen version.
That’s about a $3 price difference, while both versions are still available.
Better driver design? Both claim XPG2; any way it’s a better emitter?
I’m thinking at least these look easy to mod, as I like to swap in amber emitters.
EDIT: I asked Sofirn and was told there’s no difference between v1 and v2.
Curious, that.
hank
(hank)
47
I have a hunch about that: cycling the driver on and off probably takes a lot of power relative to keeping the LED illuminated.
I recall many years ago reading a comment from Gransee (in a discussion at CPF) who originated the Arc AAA lights — saying that once the light dropped into moon mode due to low battery, you’d get more light for longer by leaving it turned on than by turning it on and off at need, because powering up the driver sucked significant battery power each time you turned the light from off to on.
I have been wondering how the V2 model differs from the V1 — anybody know?
Both old and new models are for sale witha few dollars difference.
If the newer driver is better, for modding, it’d be worth paying more.
If it’s a different LED, which I”d expect to swap out anyhow, not so much.
hank
(hank)
48
I asked Sofirn by PM what’s the difference between v1 and v2 of the SF13.
Last chance! I grabbed a couple since I mod them for older (than me) neighbors.
