I understand that the Sofirn SF16 UV light uses Luminous SST08UV LED (and a filter - I imagine ZWB2?). Would anybody know what wavelength bin the LED is from?
Alright the newbie will bite…
Been looking for info on UV LEDs and found this orphan post. Not sure if it’s still relevant.
The only real way to know is contact Sofirn and get the exact part number they’re ordering from their supplier. According to this datasheet, they’ll be identified with which “Bin Wavelengh” in their ordering confirmation from the vendor, and likely on the packaging (reels, probably).
If you inquire, make sure to confirm how picky they are about always getting the same bin wavelength. If they change it, they may have marked boards or something, so they can have a way to inspect for that too.
Both bins for wavelength “lean toward” the more desirable shorter end of each wavelength band’s bins. This means they probably target them all to be “exactly” spec, with “out of tolerance” tighter for those bleeding to longer (more visible) wavelengths. The manufacturer should be willing to share bin stats on a one-off basis if you ask. That’ll give you an educated guess, but no certainty.
