Sofirn SK31 Review
This review is of the new SK31 provided by @Sofirn, available here:
https://www.sofirnlight.com/products/sofirn-sk31-6800-lumen-tactical-and-duty-usb-c-rechargeable-flashlight
Aside from the light itself, I receive no compensation for the review.
This is a single-21700 tactical-style flooder with ~6000lm and ~420m of throw. Click on the sections below to read more!
Basic observations
The light comes in the usual box.
Aside from the light (which comes with a pocket clip attached), the box also contains a nice holster and other accessories such as a charging cable and spare O-rings.
Here are the parts of the light disassembled:
Note that the battery tube contains a secondary inner tube, for transmitting signal from the electronic tail switch. Additionally, the charging port (and UI toggle–more on that later!) are hidden behind a twisty ring sealed by a pair of O-rings. I find this design much more reliable than the usual rubber cover, in terms of weatherproofing.
The battery tube is only anodized on the head end. The anodizing feels too thin–some anodizing was visibly eroded from the threads when I first opened the light. Hopefully this does not impact function in the long run.
Emitters, beam, and performance
The SK31 features a 6500K LHP73B in a smooth reflector, behind an AR-coated glass window. This emitter is favored for extremely high output and efficacy, as well as minimal angular tint shift. These characteristics are indeed observed–the tint is a clean cool white at all output levels, with no tinge of green or noticeable shift to higher CCT on turbo.
The reflector is of very high quality: there are no bad spots, machining marks, dust, smudges, or any visible deviation from a paraboloid. This is the best, smoothest reflector I’ve seen to date. The quality of the reflector is evident when looking into the reflector on moonlight: the gaps between dies produce perfectly symmetric reflections.
The centering gasket has a square opening and does a perfect job. Given the quality of the optical system, it is somewhat of a shame that a throwier emitter is not used.
The beam is very much on the floody side, but still retains very usable throw. Despite the 16-die structure of the LHP73B, artifacting is minimal (not visible unless one looks for it, even on a white wall!) and only present in the center of the hotspot. The beam profile is similar to that of a S2+ with LHP531, but a bit throwier and much cleaner.
I measured throw at 422m, which exceeds the specification. I have no reliable way to measure output due to lack of a calibrating light, but ceiling bounce comparisons with other lights suggest that around 6000lm is a good estimate.
The bezel is easily removed by hand, with the assistance of a t-shirt in between. The stock MCPCB can be easily de-soldered for an emitter swap–either with a LHP73B variant in lower CCT or higher CRI, or with the new F150R for throw. A quick calculation suggests that a F150R swap leaves output almost unchanged but doubles the intensity, pushing throw to 600m.
User interface
The UI is one of this light’s unique features. There is a “tactical” group that allows easy access to turbo and strobe, and another group that has 6 levels spanning moonlight through turbo. The groups can be toggled with a light-up button hidden with the charging port. Blue indicates “tactical”, and orange (really a red-green mixture to my eye) indicates the 6-mode group.
Additionally, there’s a toggle in the tail that allows for instant lockout of the light. The full UI is listed below:
I’m unsure about the exact mechanism of the switch, but it seems to involve two stages: a partial press with no tactile feedback other than a slight spring sound, and a full press that reaches what feels like an e-switch at the very bottom.
The outdoor group essentially simulates a light with a mechanical reverse switch and same-mode memory. The modes are very well-spaced, visually linear with meaningfully distinct but not abrupt increments. However, I dislike the mode memory because it makes the light unpredictable if you don’t remember what mode you left it on. Simply removing memory would have made the UI much better.
The “tactical” group creatively combines the 2 stages of the switch to allow momentary turbo during partial press and strobe when the bottom e-switch is held. However, I find the non-momentary modes (medium and turbo especially) hard to access due to the very long 5-second wait, which renders them useless in a time-sensitive situation. It makes little sense that accessing medium requires burning 5 seconds of battery on turbo. For the reason, I never use the tactical group. In the future, I suggest making sustained/lower modes more accessible, possibly by taking advantage of the double-click action commonly implemented in other e-switch lights.
Battery and charging
The light comes with a 21700 battery. Note that the provided battery has a low discharge rate and thus cannot push the emitter to the specified 6800lm–I recommend including a high-discharge cell in the future. Even with the existing cell, the output is very impressive.
Charging proceeds at a rate of about 5V 1.8A, which I find a good balance between speed and cycle life. The UI toggle button lights up red during charge, and turns green upon completion. Termination is at exactly 4.200V on my sample, which is excellent.
Interestingly, the light can still be operated by USB-C alone, even when the battery is removed! On maximum it draws the same amount of power as a regular charge, and sustains a very usable 1300 lumens. With a high CRI emitter, it could make for a very nice desklamp.
Concluding remarks
I really like this light for the creative switch and UI design, as well as the great optical quality and the capability for both very high and very low output. However, I find the UI somewhat awkward and not particular well-suited for either everyday use or tactical use. I strongly suggest revising the UI in the next iteration.
What I like:
  • Great optical quality, and best reflector I’ve ever seen
  • Charging port protected by metal ring rather than silicone flap
  • Very high output and decent throw+tint, also easy to emitter-swap
  • Great mode spacing
What I think can improve:
  • Better UI. In particular: remove mode memory in the “outdoor” group, and make lower+sustained output more accessible in the “tactical” group.
  • Include a high-discharge cell to support the high current draw.
  • A throwier emitter to go with the extremely nice reflector–the F150R should double the intensity and push throw to 600m.
  • Thicker anodizing to improve longevity of battery tube.
Thank you for reading!
