didn’t see any documentations on the chipset or disassembly instruction online so here it is:
take out main pcb assembly just heat it up good at the bottom near the spring. prefer to use hot air external just running the light isnt enough for me. loosen the glue by rocking back and forth and the whole assembly come out after you desolder the wire to the driver. for reassembly solder a thin solid wire to the driver wires to help pull thru.
MCU ft61e0a5
got it for review sample, the build quality is great and driver and thermals is good but the ui kinda mid. was hoping to flash custom firmware maybe build anduril2 for it but chipset not supported unfortunately.
no supported chipset with same or similar pinout either unfortunately. time to put back together probably use this one for the toolbox
