I need a charger for 18650 Li-ion and 26650 LiFePO4 cells that I can use a Solar Panel with. For this application the cells would be left in the charger and connected to a digital camera for external power. The charger would be used to only maintain the voltage on the cells. It would have to be able to operate with power interruptions depending on the amount of sunshine available. In other words begin a charge when adequate power is available with proper charge currents. Some chargers will lower charge current when restarting a charge after power has interrupted.
I would use the MC1 Plus with a 5 volt 8 watt panel.
My application is as follows. I intend to use the charger as not only a charger but also as a cell holder. The cells will be left in the charger to provide external power to a digital camera. The cells will be connected in parallel with the camera. I am expecting the charger to keep the cells charged up as sunshine permits. Everything will be installed in a waterproof case. This will be left in the woods to capture photographs of animals as they wander by.
Thank you,
Bill
Measurements
Below 2.9 volt the charger charges with about 70 mA (Red led is on).
Above 2.9 volt the charger applies regular charge current.
When the charge is finished the charger is charging with a few uA.
The charger will restart if the voltage drops below 4.12 volt, but the led will first indicate charge if the voltage drops below 4.09 volt (This probably depends on the actual reference voltage of the two charge chips).
Power cycling or battery reinsertion will not restart charging.
When charger is disconnected from power, but with a battery in, it will draw about 25 uA from the battery.
I understand this to mean the charger will slightly discharge 25uA at night and in shade.
Will restart charging under 4.09-4.12
I will run some test with a power supply to simulate shade. BRB
The camera remains off until an animal comes into the PIR sensor.
The control board operation for the camera is explained here. I have soldered wire inside the camera for Power, Shutter and Ground and they are connected to the control board. The control board has 3 AAA batteries that power it.
At motion, camera turns on and shutters first picture
Waits with camera on for 30 seconds for a second animal or event with the camera ready.
Can shutter the second follow-up picture or pictures within less than 5 seconds apart.
Will stay on for 30 seconds after the last picture, and then return to the selected delay routine if one has been chosen.
Awesome. In that case I think a single 18650 should keep you going. Sounds like an interesting build-hack for a game camera.
How often will you check it ?
