I’ve read a little about the resistor mod and I’d like to take some of the resistors I have from salvaged solarforce drivers (the same as in s1100) to add to the 1100 driver.
My question is what would happen if I added the same resistor that’s on there already in same spot? How many should I add. I can solder and stack them I just don’t know how they work or the electronic portion of the mod.
Should I add 1, 2 or stack them all? Or should I add different chips?
Please show a picture of the driver.
If we know which and how many resistors and how much the stock current is than we can calculate the resistance which needs to be added for your dream current.
I’ve borrowed comfychairs picture as I’m not going to open mine up until I know what I can do to increase current. Looking for around 4 or 5 amps. This uses 3 18650 in series. The resistors in question are the sets of r220 and r240.
Stock current for me is around 3.6 amps. 1.2 at tail so that’s x3.
If you lower it too much it'll go direct drive and pop the LED. I added 4 1-ohm resistors and it did around 4.3-4.4A (actual output, not calculated guess based on tail readings). Add 3 1-ohm and 1 0.5-ohm and you get a dead LED.
Use this to figure out a resistor combo: http://www.1728.org/resistrs.htm
And this to decode any unknown markings: http://www.hobby-hour.com/electronics/smdcalc.php
Since they're all in parallel, four 1-ohms is the same as one 0.25-ohm. (and three 1-ohm + one 0.5-ohm is 0.2-ohm, very fine line there between works and dead)
Thanks comfy. Maybe I’ll leave the stock led in and try a. 24 in there. If it pops I’ll try the .22 on another U2. If that pops I’ll go with the 4x1 mod with an xml2 and be happy with the 4~ amps.
Adding a 0.22 is more likely to pop it than a 0.24 - lower resistance increases the output, and adding resistors in parallel will always lower the total resistance no matter what their value. A lower rated resistor will lower the total more than a higher rated one.
