Solarforce L2 series O-Ring sizes
Does anyone have the sizes for the various O-Rings in a Solarforce L2, preferably a L2M series, flashlight? I’ve searched the forum but although the o-rings are mentioned the sizes are not. I have tried to measure them myself, but my eyes are not that great. They look like 25mm x 2mm for the head sided tube, and 20mm x 1 or 1.5mm. Can anyone confirm this?
I am putting an order in for parts and pieces and thought it would be smart to get some o-rings as well. Probably will get some green or orange ones just for fun.
I’m also getting some extra colored tail cap boots. I understand the width size is 14mm but is the depth 7.5mm on the boot?
Thanks
On the L2N and L2P the tail end would be 20mm X 1.5mm and the head end 25mm X 1.5mm being as they will all “Lego” together this should be true for the L2M Head and the mid join and tail end.
I see on the Fast-Tech website they quote both the inner and outer diameter. Are those diameters you quoted inner or outer? Also, do you know who sells the flat rubber ring for between the bezel and lens? Thanks for the help.
That would be the inner diameter, a mm or so smaller won’t be critical but larger and you’ll get a loose O ring that could foul the threads and not seal. Unfortunately I have no source of the L ring that sits between bezel/glass. Solarforce have always been very good with me when it comes their customer service so an email to them might get a result. Don’t forget that it’s a Holiday weekend this weekend so if you email them today they might not see it until they are back at work.
Hello 8Steve88, running into you everywhere. :>) I tried to measure the O-rings again and here is what my bad eyes came up with. The head side rings are 20mm ID x 3mm x 26mm OD. The tail cap side are 17mm ID x 2mm x 21MM OD. Unfortunately, all the O-rings on Fast Tech are the wrong size and I can’t find any other flashlight stores that carry them. Some local hardware stores do carry O-rings but they charge more for 1 O-ring than Fast Tech charges for a dozen.
Would these be the same size for a L2D please ?.
How many O rings are there in an L2D?.
Could you tell me the sizes I need for a complete replacement.
Bezel body and tail o ring sizes.
Thanks
