Solarforce L2 w/xml 5 mode drop in automatic unwanted mode changing while biking help!
Hi, I got a solarforce L2 with their “880 lumen” 5 mode drop in. I mounted it to the handlebars, and now whenever I hit a bump at the wrong rate the mode changes. It’s pretty annoying as I hate the flash. So my question is what’s wrong? Do I need to repair the switch at the back or the dropin? I’m just wondering what the most likely problem is. I’m pretty handy, but I wanted to benefit from the knowledge of the more experience before tearing this thing apart.
Some background is I’m not totally happy with this light because I hate riding with flashy mode, the dropin has an unsuitable beam pattern for cycling, and to change from low to bright I have to click through tons of useless modes. I ride with this thing mounted on my handle bars, and it works okay as the light primarily helps me to be seen by others, as neighborhood lights are sufficient to allow me to navigate. So if it was likely the dropin causing the problem, I could easily be persuaded to purchase a new one if it wasn’t too expensive. I’d be okay just repairing this one too though.
Thanks for any help.
sounds like your cell is making and breaking contact or the negative spring on the drop in.
Try taking the light off the bars, turn on and shake it to test.
If the battery is a little loose in the battery tube, put some tape around it to stop it moving and hopefully stop it from disconnecting to the negative spring.
I wrap masking tape around the cells I use in my bike lights until they are a snug fit in the light . When the cells are unable to move around much , unplanned mode shifting is minimized .
That being said , if you are doing some fairly rough riding , a single mode XML dropin with an OP reflector will probably be your best bet .
Put some flat magnets on the battery´s end.
I think the same as gords. Usually a drop-in changed the mode, if you use the clicky (this will break the voltage for a short time). If you hit a bump the battery will moves and lost the connection to the spring. This will change the mode like the clicky.
Solution: You have to find a way, that the battery and the spring will never loose contact.
For example enlarge the length of the battery (with 1-2 small coins, which fit) or try to reduce the moving of the battery to left and right. I use some paper to roll the battery in.
This exactly. I have a very hard time using multiple mode P60 lights on my bike (even just on the sidewalk).
1-Mode XM-L all the way.
are you using protected cells? they are little longer and should work better (xtars or protected panasonics are quite big for example)
I have no doubt something is making and breaking the connection. There is surely a bad connection somewhere. I hope it’s not in my cells. Anyway, I am using protected cells, but I’ll have to try the masking tape and magnet tricks. This problem has developed over time, which makes me think it could be corrosion related. Hmmm. Thanks for the input, let me know if there are any other remedies I should look into.
I have determined the problem and implemented a solution. In the tail cap there is a ring making a connection between the tail cap body and the board upon which the switch is mounted. This ring came loose. Tightening it solved the mode change problem. I then placed a copper wire bent into a circle shape above the ring such that when the tail cap is installed the ring cannot vibrate loose because the flashlight body now stops on the copper wire rather than the the top edge of the tail cap.
