Since I have a SolarForce L2N XM-L U2 coming in the mail already and SolarForce has the L2N body on sale for $12.99, I decided to get another L2N and with a SolarForce XP-G drop-in.
The low volt .8-4.2 single mode is driven hard. 2.6amps. I use it in my l2n I have a 3 mode xpg and its driven at 1.8 on high, still good but the single mode is a great thrower.
The XP-G will throw further. An XM-L in a P60 sized reflector would produce a very fat hotspot, whereas an XP-G would produce a smaller, but brighter hotspot even when driven at a lower level.
Also, I’m not sure if his applies here considering what was mentioned above, but the drive current is also a factor to take into consideration. A drive current of 3A or more in a p60 host can get toasty real quick, wheras a similar light driven at 1.5A can be kept on high indefinitely without becoming too hot to hold. Not an issue if you use high for only a few minutes at a time though.
