Solarforce M9
Ok I will admit to being a bit thick between the ears and this has LED me to my problem.
My Solarforce M9 was good with 1 Panasonic 3400 mah 18650 and brilliant with 2.
So me being me I tried 3 and the result is why I am writing this post.
The LED will just glow like it is stuck in moon mode.
What have aI broken ? is it now a pretty paperweight or can it be repaired ?
Any advise ?
Please
Sounds like someone is going to have to take it apart to troubleshoot it. That looks like a pretty good light, would hate to loose it… But would be fun to mod it! :slight_smile:
This is the beginning of your new modding hobby. The driver is fried. The LED might be fried. Time to strip it down and rebuild it with the help of the flashaholics here. Just think of all the good parts still on it. Your old driver was rated for 2.7-9 volts by the way. This new build is a little tricky because of the side electronic switch. Start by stripping it down post pictures and let us point you in a proper direction.
Just a guess, but you may have fried the driver. If you had 3 fresh/charged 18650s, you fed it over 12.5V, when it's likely only rated up to 9V.
EDIT: Looks like TS beat me to it. Just a good excuse to mod it IMO. Maybe XHP70?
careful disassembly… find the driver board… carefully remove and measure diameter and check height of tallest component(s)… find suitable replacement, with “appropriate” output power…
basic nuts and bolts, basic de-soldering and re-soldering skills. Good first “mod” job to tackle. hey, you gotta get yer feet went sometime? and hey, you cant HURT the light, as it already needs fixing, right? have fun… and ask questions as you go…
“the only stupid question is the one you didnt ask”
you might need a new LED, or… you might just want to take the opportunity to get a new LED emitter on a copper star and swap that too, make th thing JUST how you want it to be. If your gonna make it as bright or brighter than before? why not choose your emitter and tint while your at it?
hey, after you get THIS done? you’ll be “fixing” lights that are still working perfect, LMAO…
Ok you blokes have talked me into “it”
I will take some pics as I pull it apart BUT I will need a lot of help as my soldering iron is still sitting in the forge. :-/
Has anyone any idea how to remove the dodad with the switch thingy to get at the other bit.
