The Solarforce MPP2 never really got a lot of love.
I bought mine as a pair, along with the MPP1 thrower head, which still does pretty good, considering it's using an under-driven XR-E.
....But the MPP2...never really done much for me. It's just been sitting there on the desk, inching further to the back, making way for other lights, parts, empty packets, etc. It was way up the back there, coated in dust.
Wanting to try out the new XHP emitters, I figured that the MPP2 may be a good host, as it already sported a good OP reflector that done a nice job of smoothing out the old MC-E.
So blew off the dust, & stripped it down to take a closer look;
So it's basically an over sized P60 pill, floating on top of a spring. Not good for heat transfer...
I started looking around in the parts bin to see what I could do, & found that the old brass P60 pill threads were the same.
The stock pill is rather tall, so I had to re-create the height as well.
I joined up the two P60 pills using a copper sleeve, & attached the collar, which will get sandwiched between the reflector/pill & battery tube when the light is assembled.
The XHP50 was transferred onto a 16mm Noctigon, which was also soldered to the new pill assembly.
I had to play around with the pill height a little before I was happy with it, & ended up having to use another copper spacer.
I was originally hoping to use the stock driver, but decided against ripping it apart.
Instead I put together a zener modded MTN17-DD, & also went to work with resistance mods at the top & bottom.
I wasn't going to do anything with the dome of the XHP50, but due to a glancing blow from the blue tongue of the blow torch, I gave it the shave, after practicing on a few dead XM-L's.
Everything worked out really well. I tested it out with some laptop pulls at first, & was really happy with the output & beam profile.
Then I decided to whack in a pair of 25r's, & take a amp reading at the tailcap. It showed close to 9 amps on my old multimeter with beefed up leads.
Then when I turned it over, I saw a nasty black spot on the LED surface...
Ouch! I forgot to clean the crap off the LED - there was some fine metal filings on it, & I was going to clean it up with some alcohol, but got carried away..
It's currently in the petrol soak, but I don't hold too much hope for it. I've got another on the way if it doesn't work out....
==Update 30th May==
The postman turned up yesterday, brandishing a familiar yellow envelope. Inside were my replacement XHP's.
Those of you who have had to re-flow an LED on a copper board, soldered to a large multi-piece pill, will now feel my pain....
.... With the pill rebuilt, I spent some time tweaking the height of the emitter, & ended up enlarging the reflector opening to get around clearance problems with the pill & wiring.
This was the final result;
Stock performance with the old MC-E was around 670 Lumens.
Bringing it up to current standards (pardon the pun), the XHP 50 is punching out over 3600 lumens peak at start-up, then dropping to around 2200 after 30 secs, with heat being an obvious factor.
I'm glad I programmed a few lower modes....
:beer:
