Hi,
one year ago i modded the SolarForce S1100 to XM-L2@5,7A but switched on the light only once since then. So the light had to become more interesting
From the mod of the NiteCore TM36 i had a Luminus SBT-70 left over and combined that with a LD2 12A driver. The driver was connected to the original contact board. I glued a nut on the mosfet and glued that nut to the inside of the body using Arctic Silver. The rest of the gap between driver and body was filled with Fujik.
To get the LED into the focus i soldered two old copper MCPCB together and put these underneath the LED on Noctigon.
The LED was glued into the pill.
I changed the battery carrier to parallel. The spring bypass was done, too but is not on this picture.
The spring were bypassed
All parts of the light.
The aspherical lens is deep in the head. The lens is hold by a ring of plastic, here with some GITD foil. I removed that later.
A lovely LED
I measured 212 Klux@1m.
Here some beamshots compared to my Jax Z1 with dedomed XP-G2 (~200 Klux)
Distance to the weir ~160m, Nikon P100, f=3,2, 0m5 Sec., ISO800
Controlshot
And a little video edit.
Now this flashlight makes a lot of fun! I always wanted that round image
Greetings
Kenjii
