Solarforce T1 barely used but won't turn on
I recently purchased a Solarforce T1 directly from the manufacturer. However, I have been having quite a bit of trouble with it. It generally turns on, but every once in a while it wont. I have to shake it, turn the screw to change intensity, and every once in awhile it will turn on. Dropping it once (when shaking) also helped it turn once. Is there a quick fix for something like this, like putting a penny under the battery? What could be the problem or is there some fool-proof way of turning it on aside from pressing the button?
First you need to know where the problem is—try removing the tail cap—then use a screwdriver and touch the neg(back of the battery) to the bare aluminum of the battery tube—if the light works fine it’s in your tail cap—if it’s the tail cap— it could be a few things—loose retaining ring—retaining ring not making good contact with the end of the battery tube—it’s a trial and error type of thing
I think the T1’s have been as bit problematic, mine went very flickery. Solarforce however sent me a new head for it and problem solved. I’d recommend emailing them and asking.
If you’re using 18650s, the other variable is battery length. Shorter (sometimes unprotected, sometimes flat-top) batteries can tend to rattle more. In a pinch, I’ve padded things out with a flat disc magnet on the (-) end.
