MSRP: $275
Sales is as is!
In new-like, mint condition. Only used a few times.
Included in the package:
- K65 flashlight
- Holster
- Lanyard
- Spare O-rings
- User manual
- Retail Packing Box
Acebeam K65 - a powerful hand led flashlight, which is an improved version of the most popular flashlight K60. K65 adopts the Cree XHP70.2 de-domed LED, which allowed to increase the brightness of the light flux to 6200 lumens, also maximizes the output potential of the Cree XHP70.2 de-domed bulb with a peak beam intensity of 257000cd. In addition, K65 is distinguished by the increased luminous flux, which helps the beam distance up to 1014 meters. The side pressure switch makes the operation much easier to cycling from all brightness levels. K65 is impressed by a thoughtful design and a high quality construction. The special surface structure makes the lamp firmly and securely in hand. K65 is an unmissable light when outdoor activities.
- Cree XHP70.2 LED De-Domed
- 6200lumens
- 257000 cd Throw 1014M
Features:
LED: 1*Cree XHP70.2 LED De-Domed with lifespan of 50,000 hours
Turbo Brightness Output: 6200 lumens powered by 4* 18650 batteries (ARC18650H-310A)
Output Mode & Runtime:
Eco 5lms (60h)
Ultralow 250lms (21h)
Low 700lms (10h)
Medium 1700lms (4h)
High 3500lms (1.5h)
Turbo 6200~4000lm (3min~1.2h)
Strobe 6200lms (~)
SOS 1700lms (~) -
Working voltage: 12V to 16.8V
Max beam distance: 1014 m
Peak beam intensity: 257000 cd
Impact resistance: 1.2 m
Waterproof: IPX-8 (2m)
Size:190mm(length), 90mm(head diameter), 53mm(tube diameter)
Weight: 660g (23.3oz) without battery
Material: Aircraft-Grade Aluminium Alloy Type6063&Premium type III hard anodized anti-abrasive finish -
Reflector: Smooth reflector gives perfect beam&throw
Over-distance beam throw up to 1014 meters,applicable for wide-range searching
High efficiency circuit board provides max runtime up to 60 hours
Toughened ultra-clear glass with anti-reflective coating
Convenient side switch for one-handed easy operation
Stainless steel bezel protects the core components from dam
Tail-stand capability design for candle usage
Superb light of amazing constant brightness due to powerful electronics and active temperature control without timers
ACEBEAM K65 super brightness multipurpose searchlight is your best choice when hunting, searching, rescuing, securing, caving etc.
Power Indicator:
- Green indicator >30%
- Red indicator <30%
- Red flash low power warning <10%
- Turn off automatically <1%
