SOLD! Brand New Crelant CH10 xm-l2 with samsung 25r 18650 and charger $38
This is a brand new crelant ch10. this is open box i only checked it for functionality. works perfect looks perfect. comes with 1 samsung inr18650 25r. this battery is 2500mah and has a 20 amp max discharge rate. and also including an 18650 battery charger. $38 . free shipping conus. insured with tracking number.
here are the specs from crelant
CREE XM-L2 LED with 50 000 hours life span.
- Maximum output: 460 lumens (ANSI FL-1 standard)
- High efficiency constant-current circuit and output-luminance
- Durable, custom-designed microcontroller drive circuit
- Switch (High, Low, Hidden Strobe and SOS, infinitely variable brightness).
- Working voltage: 2.7V—8.5V DC
- Battery Types Supported: 1 x 18650 or 2 X CR123A
- Runtime: High output at 2A: 460 lumens for 186 minutes.
Low output at 0.3A: 120 lumens max for 8 hours
- Mil. Spec. Type III hard anodized aircraft grade 6063-T6 aluminum alloy
- Color: Black
- High performance aluminum OP reflector for large spot
- Waterproof: IPX-8 Standard
- Lens: Toughened & ultra-clear coated and anti-abrasion glass
- Dimensions: Length 80mm, Head Diameter 26.5mm
- Weight: 66g excluding battery
  • Accessories: Headband, Spare O-ring
price drop to $38
It would help to provide some pictures. Absolutely no offense intended, but there’s a bit of convincing required from new members to show you have the item and it’s in the specified condition.
$35 is a decent price. Good luck M8.
i appreciate the input. thank you.
How do you expect to be paid? Do you take PayPal? Check? Money Order? Interested but need to see pictures as well.
sorry i need to mark this sold, thank you
