SOLD
Crelant V11A XML-U2 in excellent condition.
Very lightly used. Almost like new. Mostly lived in a “go bag”, out of sight and mind.
Apparently some folks have had questionable experiences with the newer genII 2xAA V21A model. This V11A has been fine with no problems I can tell. Switch works great. No flickering. Solid. Just making room for some newer purchases that get more use… and some more new ones still on the way to me!
You know how it is….
Mfr Specs:
- CREE XM-L U2 bin LED with 50 000 hour life span.
- Maximum output: 450 lumen
- High efficient constant current circuit and output-luminance
- Microcontroller drive circuit
- Working voltage: 0.8 - 4.2 VDC
- Battery Types Supported: 1 xAA,1X 14500
- Runtime(14500): High output at 1A: 450 lumen max for 56 minutes.
Mid output at 300mA: 128 lumen max for 151minutes.
Low output at 30mA: 13 lumen max for 25 hours
- Mil. Spec. Type 2 hard anodized aircraft grade 6063-T6 aluminum alloy
- Bezel: stainless steel
- Colour: Gray
- Tactical forward tail cap switch
- High performance aluminum OP reflector with concentrated beam shot
- Waterproof: IPX-8 Standard
- Lens: Toughened ultra-clear coated and anti-abrasion glass
- Candle function with ability to stand on tail cap
- Dimensions: Length 107mm, Head Diameter 23mm
- Weight: 54g excluding battery
- Accessories: Lanyard, spare o-ring
Please note! This is not my pic of the light for sale. Found via google and added for coolness. This actually looks like a darker gray ano than the one I am selling but it is hard to tell exactly with the lighting of that shot.
SOLD
SOLD
SOLD
