MSRP: $220 (did not include batteries)
Asking: $79
Sale is as is!
Package Contents:
- Fenix FD65 Flashlight
- 4x Fenix ARB-L2-3400, 3400mAh
- Lanyard
- Holster: for hip or belt storage.
- Spare O-Ring:
Product Overview:
The Fenix FD65 Focus Flashlight is a beast of a light in fairly compact form. Its neutral white LEDs and high-efficient TIR optical lens allow this flashlight to blast 3800 lumens of light one-quarter of a mile when focused to a tighter 10° spotlight. For a wider beam, simply twist the flashlight’s head to transition to a 90° floodlight (for greater close-in visibility). The simple operation of switching through its 5 light levels and 2 strobe modes are done by its highly functional side switches that are built into the compact 6″ long and 2″ diameter body. Waterproof/dustproof design continues the long list of attributes that make this the ultimate tool for search/rescue, security and professional applications.
Product Overview:
Specifications:
- Max Lumens: 3800
- Max Beam Distance: 1345 feet (410 meters)
- Max Runtime: 86 hours
- Lighting Modes: 5 brightness levels, strobe, and SOS
- Bulb Type: Cree XHP35 HI neutral white LED
- Size: Length: 6.0″ (152.2mm) Body: 2.0″ (50.5mm) Head: 2.4″ (61mm)
- Weight: 15.2 oz. (431g) excluding batteries
- Battery: Four 18650 rechargeable Li-ion batteries (not included) NOTE: The light will not work with flat-top 18650s nor any of the micro-USB batteries * like the Fenix 2600U/3500U. We recommend any of the other ARB-L18 series from Fenix.
- Included: Lanyard, holster, spare O-ring
More Information:
- Cree XHP35 HI neutral white LED with lifespan of 50,000 hours
- Powered by four 18650 rechargeable Li-ion batteries (not included)
- 431 grams (excluding batteries)
- Low and High separately controlled for powering on
- Momentary on SOS and Strobe
- Dual side switches for separate upward and downward output selection
- High efficient TIR optical focusing lens
- Fitted with 1/4’’ threaded interface (Standard tripod socket)
- Digitally regulated output maintain constant brightness
- Reverse polarity protection, to protect from improper battery insertion
- Intelligent overheat protection protects from high surface temperature
- Made of durable aircraft-grade aluminum
- Premium type III hard-anodized anti-abrasive finish
