SOLD - Fenix LR40R V1.0 - 12,000 lm, 2,100 feet (640 meters) - $99
MSRP: $280
Sales is as is!
Mint condition. Complete.
he Fenix LR40R V1.0 (often queried as ldr40r) is a high-performance, ultra-bright searching flashlight designed primarily for search and rescue, outdoor exploration, and heavy-duty utility. According to the manufacturer specs on Fenix Lighting, it delivers a massive combined output of 12,000 lumens and a maximum beam distance of 2,100 feet (640 meters).
The full technical details, features, and physical specifications of the original V1.0 model include:
Core Output & Beam Specifications
• Combined Maximum Output: 12,000 lumens.
• Maximum Beam Distance: 2,100 feet (640 meters).
• Maximum Runtime: Up to 92 hours and 18 minutes on its lowest setting.
• Light Source: Cree LEDs separated into distinct spotlight and floodlight structures.
• Lighting Modes: 4 Spotlight brightness levels, 5 Floodlight brightness levels, Strobe, and SOS.
Battery & Charging Infrastructure
• Primary Battery Pack: Powered by an included ARB-L37-12000 rechargeable Li-ion battery pack (12,000mAh), which houses four 18650 cells arranged in parallel.
• Emergency Versatility: In a pinch, it can run on one to four individual button-top 18650 batteries, though performance (like Turbo mode) may be restricted compared to the official pack.
• Power Bank Functionality: Features a USB-C fast charging port for internal recharging and a standard USB-A discharging port to charge external mobile devices.
• Power Monitoring: A 4-LED indicator array near the switches maps out remaining battery level with a quick single click.
Physical Characteristics
• Dimensions: Length of 6.1” (154mm), Head Diameter of 3.2” (80mm), and Body Diameter of 2.0” (51mm).
• Weight: 17.6 oz (500 grams) excluding the battery pack.
• Build Material: High-strength oxidation-resistant aluminum body paired with a stainless steel bezel.
• Tail Standing: The flat tail design allows the flashlight to stand vertically securely for ambient room/area lighting.
User Interface & Functionality
• Dual-Switch Control: Features two stainless steel e-switches on the side—one strictly managing the spot/throw beam and the other handling the floodlight array. Both can be operated completely independently or combined for maximum output.
• Memory Function: Automatically returns to the last used brightness setting upon power up.
• Electronic Lockout: To prevent accidental activation while transporting, pressing and holding both buttons simultaneously for 3 seconds locks the digital interface. Repeating the action unlocks the light.
Included Accessories
When purchased, the standard retail kit includes the flashlight, the ARB-L37-12000 battery pack, a heavy-duty adjustable holster, a USB Type-C charging cable, a lanyard, and a spare O-ring.
If you are looking to buy or compare, please note that Fenix has since released the LR40R V2.0, which bumps total output to 15,000 lumens, implements a physical mechanical toggle switch, and uses a non-replaceable built-in battery pack instead of the removable setup found in this original V1.0.
