SOLD!:WTS: FIREFLIES E07, 6900 lm, XPL Hi V3 - new but needs some repair
SOLD!
Fireflies E07-5000K, 6900 lm, Worked for half and hour, then something happened with the driver maybe? it comes on but at max power only, cant change it, only changes slightly but still stays close to max power only. Maybe someone can fix it or use parts. Also,i messed up the rubber covering over the button,but the button itself is not damaged. I bought it for around $80.
Will sell for $30 with Free Shipping, i also have a clip for it
Always nice to see a direct image
Don’t know why this is not working for me. I tried exclamation marks around it and the image just disappears. Thank you
I’ll take it….send me PP addy…
You can add your location to your profile so we don’t have to guess
Oh ok will do. I’m in the NYC
just to clarify, the light comes on as soon as i twist the tail end tight and stays on max power, so basically doesnt react to the clicks. to turn it off i have to give the the tail end a twist again.
If i doubleclick it very very slightly reduces the lumen output and when double click again, it goes back to the max. doesn’t seem to react any other way.
Do the aux turn on (what color are the aux LEDs)?
For science. :slight_smile:
Had the same thing happen to mine sent it to Vihn turned out it was the switch.
Does it work now? When you switch switches?
Thank you, @Cloud! It finally touched down, today.
Wow super bright! Will only come on full force….
Cleaned contact surfaces, could be a short .
Left the pocket rocket on for a while. Until too hot to hold.
Cool down. And walla!
Functional now. Steps up/down. Turbo. On/off. Etc.
Thank you, Sir Cloud, even if it took 3 agonizing weeks for snail mail to get from NYC to
Western Mass.
But in the end, a two thumbs up! :+1: :+1:
Man, that’s fantastic. You sure have the magic touch!
Prolly just the luck of the draw. Again, thank you! :beer:
