Hello guys!
Up for sale is an EagleTac M3C4 Cool White XM-L Flashlight, it comes with everything stock including Box, papers and 2 Trustfire 2500mah (Manufacturer rated) 18650’s protected batteries.
Specifications:
Model:
EagleTac M3C4 XM-L LED Flashlight
Max Output Power:
748 Lumen with 39,840 Lux at 1 meter
Continuous Runtime (Manufactuer ratings):
Turbo - 748 ANSI lumen (1.5 hours)
High - 404 ANSI lumen, (3.5 hours)
Med - 192 ANSI lumen, (8 hours)
Low- 65 ANSI lumen, (28 hours)
Very low - 5 ANSI lumen (100+ hours)
Operation/Functions:
Dial the ring to turn the flashlight on/off, adjust between the five brightness levels, and access the three hidden modes (strobe, fast beacon, SOS). To access the hidden blinking modes, turn the ring from the turbo mode to the off/standby mode, then back to the turbo mode within 2 seconds to cycle through the hidden modes.
Lamp Type:
CREE XM-L T6 LED Cool White led
Reflector:
Smooth for max throw
Battery type:
2 x 18650 rechargeable or 4 x CR123A primary (Trustfire 18650’s 2,500mah protected batteries included!)
Housing Material:
Aircraft Grade Auminum
Body diameter:
1.5 inches (4cm)
Bezel diameter:
2.4 inches (6.2cm)
Length:
6.5 inches (16.5cm)
Weight:
12.5 ounces (excluding battery) (356gram)
Finish:
Hard Anodize HAIII finish in black
Water Proof:
Yes - IPX8 Standard
Anti Roll:
Yes
Beam Characteristics:
Good Balance of Throw and Flood with good side spill for close up
Condition:
Bezel has very tiny dots of the anodize missing, tried to photograph as best as I could, besides that is basically new, can send more detailed pictures if necessary. Functionally everything works perfect!
Price: $79 $77 $75 Shipped USPS priority with delivery confirmation, I accept PayPal from confirmed email addresses and will ship to the confirmed PayPal address only. Will send delivery confirmation and proof of shipment once payment clears.
This light is also being advertised for sale at another forum, so first to post their unconditional “I’ll take it” on either forum gets it! (Will check timestamp) If sale not completed with prompt payment in a 24 hr. period, the next person in line will have priority.
Now for the pictures:
