SOLD - Lumintop GT Mini Pro - 3500lm, 750m EDC Flashlight - $29
MSRP: $50
Sale is as is!
Battery not included!
NOTE:
I’ll be posting a lot more lights; around 40 more soon. So to save time, I’ll upload actual photos upon request.
The Lumintop GT Mini Pro is a compact, high-output EDC thrower flashlight powered by a Cree XHP50.2 LED, delivering up to 3,500 lumens and a beam distance of 750 meters.
Key Specifications
• LED: Cree XHP50.2
• Max Output: Over 3,500 lumens
• Beam Intensity & Distance: Over 57,753 cd; 750 meters max throw
• Battery: One button-top 18650)
• Driver: 29.5W, 9A FET driver (parasitic drain while OFF is ~27 μA)
• User Interface: Default smooth Narsil ramping UI, conventional discrete level mode-set UI, and momentary mode, plus instant access to turbo
• Material & Finish: Aluminum with Type III hard-coat anodizing and a smooth aluminum reflector (43 mm ID)
• Switch: Tactile button with a back-lit rubber boot
• Protection & Rating: IP68 waterproof (rated underwater up to 2 meters); anti-reverse battery design
• Dimensions: 50 mm (head diameter) × 132 mm (length)
• Weight: 150g (without cells)
I’ll take it.
PM incoming.
