Should be around 1000-1100 lumens.
Tint is a creamy neutral white with 92 CRI.
Colors are really great and with a floody beam this is a good mid range light.
I didn’t go crazy with a FET driver because of the stainless steel body which is not as good as alumnum to dissipate heat.
I wanted a reliable light, and am glad I did because I’m plenty confident to sell it that way.
Oh, btw the protected 18650 is included. Heck I can even send a charger with it.
This one is haunted or something…
Second potential buyer, second that went MIA…
Maybe I should keep it, because people interested in it seems to vanish (well not really, seeing recent activity of said members…)
So, anyone interested ? Maybe a better price would be more motivating ?
Come on, let’s say 70€ shipped to EU, additional fees are on the buyer if from anywhere else
Sorry to resurrect this “old” thread, but last night I got intrigued with this triple version of the LT Prince!
The spacer you used is in any way close to a S2+ spacer?
Also, is the tail switch “smooth” or is it noisy?
This host seems a nice candidate for a triple mod
Thanks in advance
Hey no problem bumping an old thread as long as it is to ask questions
IIRC the spacer I made was quite close to what you’d do in an S2+
The trick with the Prince is to reverse the stock copper pill (which is smooth, not threaded) and place an o-ring in the MCPCB cavity to allow the driver to sit in it without making shorts.
The old driver cavity is then filled with a copper spacer (length unknown, sorry) to allow the new 20mm triple MCPCB to sit on it.
EDIT : here are the stock pill pics I took when I had it
Sorry it’s all I got…
Oh, I forgot to answer about the tail clicky.
I would have prefered a better quality feeling, IIRC the click is ok but there’s some axial play between the steel button and the housing.
I think it’s a standard omten under there
Hey - X3-!!
Thanks so much for your answer Indeed I needed to ask this because I thought it would be different from a S2+ and it is! But not that much so I guess that with your indication this can be a easy mod Not that I have the light or the parts, yet, but that may work well
BTW, forgot to ask: The driver can be double sided or is it better to just have 1 populated side?
The tailclicky…well, gotta live with that if I go for this light, there doesn’t seem t be much space for changes at that level, right?
Thanks again for the answers and the picks, that help to see how it looks like
