MSRP: $170
Sales is as is!
Mint!
The Manker MK35 Version 1 is a powerful long-range thrower flashlight powered by four 18650 batteries.
Key Specifications:
- Emitter: Cree XHP35 HI LED Cool White
- Maximum Output: 2,550 lumens
*Max Beam Distance: 1,420 meters - Max Beam Intensity: 504,100 cd
- Working Voltage: 11.2V – 16.8V with over-discharge protection
- Durability: IPX-8 waterproof (up to 2 meters) and 1.5-meter impact resistance
User Interface & Modes
- Standard Modes: Moonlight, Low, Medium 1, Medium 2, High, and Turbo.
- Operation: Single click from off usually accesses Moonlight or last-memorized level depending on click type; single clicks cycle through regular levels, and a long press turns the light off.Turbo: Double-clicking from on or off jumps straight to Turbo mode.
- Engineering Mode: Allows you to customize and select your preferred brightness level for the moonlight mode.
- Lockout: A specific sequence (single click, double click, triple click) engages electronic lockout to prevent accidental activation.
