SOLD Modified Tangspower KUNG - With beam shots
SOLD
Up for sale is this modified Tangspower KUNG. 4x XM-L leds, (cool white), on the stock aluminum star, but backed up by a 1/4" thick copper heat sink that is pressed in the head. Uses a master/slave setup with a total of 40x7135 chips, so it should see about 3.5 amps per led. There are 5 graduated modes, from low to high and no mode memory. Turn it on and tap quickly to advance the modes from low to high and you can also go backwards, with just a little longer tap. Forwards it shuts off after high and backwards it shuts off after low, but it will always turn back on, in low mode. I thought I would not like that, but I kind of do like turning on in low mode. High heats up VERY fast, with that copper heat sink in it. It's bright as hell and a great floody light. I might do beam shots tonight, but the beam looks like every other multiple king clone that I've done before.
tp1
tp2
tp3
tk1
High mode
Five levels of power shown below
tk2
tk3
tk4
tk5
tk6
It's a nice light and very bright
yk7
It needs some good high amp 18650 batteries in it, to do it justice. One way to regulate the power would be to use batteries that will only do a lower amp draw, to keep it from being as bright on high, if that's what you want, otherwise, some good Sony, Efest, Panasonic or Samsung batteries should put out the amps for you. After all, you're talking about 12-15 amps on high, depending on the cells. Divided by four, that's about 3-4 amps per cell... IF the cells are balanced, but I would still use the higher drain cells. With high drain cells, you could even just use two cells instead of four, to lower the weight and save on cells. Remember, it holds four, but you only need one to turn it on.Wink
Price is $50 Shipped Priority CONUS - International add $10 to that price, to get it to you via regular ail mail.
Payment is PayPal oldlumens(insert the @ sign here)gmail.com
First person to post here, pay and PM me with your full name and address, gets the light.
Thanks
by the time u do beamshots, this should be gone…… but I would love to see them.
Twenty minutes later and this light is unsold ?
If you do not have a multi-emitter soup-can style light , this is as good as it gets , folks .
Wow that is a great price for a great light. I would all over it if I don’t have something similar coming in!
Beam shots added
Damn - I already have a quad light on the way…
(and another 60$ are not in the plan)
great light!
I’ll take it
I’ll be second in line if sales falls through or you build another.
You got it.
I would love to do a few of them and a few of a couple other lights, but it always ends up too much money. This one was lower price because the light itself was gotten low price, but if I did a batch of them, then they would end up being higher priced, due to it being hard to get cheap deals most times. I keep thinking about it, but never do it because of that and because of never having the bucks to buy ten of some light, when it is a really good deal...
Such is life...
