MSRP: $200
Sales is as is!
Mint!!!
The Niwalker BK-FA30S is a high-performance long-throw searchlight featuring a maximum output of 2,200 lumens and an impressive beam distance of 1,600 meters.
Key Specifications:
- LED Emitter: Cree XHP35 HI (Cool White, ~6500K)
- Max Output: 2,200 lumens
- Peak Beam Intensity: 650,000 cd
- Max Throw: 1,600 meters
- Battery Configuration: 4 x 18650 high-drain batteries (via a 4S battery carrier)
- Modes: Six brightness levels ranging from Moon (0.2 lumens) up to Turbo (2,200 lumens), plus hidden special modes.
- Dimensions: Approximately 225 mm (length) x 100 mm (head diameter)
Weight: ~730 g (without batteries) - Waterproof Rating: IPX-7
Features:
- Triple Switch System: Features a unique multi-function switch layout with a main electronic switch and two auxiliary side buttons that can be programmed to jump directly to preferred output modes (like Turbo or Moon).
Body Build: Aircraft-grade aluminum construction with a mil-spec hard-anodized finish and a smooth reflector optimized for ultra-long-range throw.
