SOLD- Purple MT-G2 2D maglite with rebel reflector-SOLD
Hi All,
Up for sale is a 2D maglite modified with a 4000K MT-G2 under a stippled mag rebel reflector and a 52mm AR coated lens. The driver is a BLF17DD FET driver zener modded for two lithium ion cells in series. The driver is flashed with STAR firmware featuring four modes (low-med-high-turbo) in ascending order and off time memory. This light draws around 8.5 amps from a pair of powerizer 26650 cells. The main emitter power is routed around the switch to reduce resistance and protect the switch.
The heatsink is a 3/4" thick chunk of aluminum rod wrapped in copper sheet. The original spring has been cut down and resistance modded with 22 gauge wire to accommodate unprotected cells. Under the original spring is a C mag spring retained in the cap with epoxy (also resistance modded) which can be used if the buyer prefers to use protected cells. This light will function with protected and unprotected 18650, 26650, and 32650 cells.
See pics below.
It is 60 yards to the sugar house.
Price includeing CONUS shipping is $115. International buyers pay actual shipping.
First reply with "I'll take it" followed by PM gets the light.
My paypal address is kyfishguy@yahoo.com
Thanks for looking,
Brian
DAAAAMMNNN Nice light!! Wish I had the money :frowning: Currently preventing myself from ordering anymore for the next 3-5months. Bought 7-8 lights in under 2 months. Now saving up for a Waterfield Staad from sfbags.com . Would love to buy one of your wonderful builds one day :party:
PM sent.
I have that exact same single sided FET Driver.
How do you wire yours? I see you have the ground from screw of Mag switch to the (-) on board.
What does the other black cable go to? the Negative on the copper board?
The red positive I take it goes from the () on copper board all the way to the bottom of the () where the cells would normally hit right? (this is normally done to force the high amperage load away from the factory Mag switch. Since you have a FET the FET absorbs the current and happily does while remaining cool.
Awesome build by the way. I got 3 of them identically built and some with big heads too.
You gotta try a FET DD XPL Dedomed from Mtnelectronics and if you get low vF and 6A~ plus at tailcap you will see well over 100K lux from factory Mag reflector.
Thanks,
bigC
Hi BigC,
You are entirely correct about the wiring. I always wire mags this way unless I'm running a buck driver.
Brian
sorry, but I think I got the information wrong or not clear. Just a last simple question and hope to copy you BTW!!!
_What does the other black cable go to? the Negative on the copper board?, I want to be clear the Negative on copper board goes to Positive on FET Driver right?_*
Thanks a million, bigC
Hi Bigc,
There are three wires attached to the driver. The first is not visible in the pic above as it runs from the positive switch terminal to the positive on the bottom of the driver. The second runs from ground via the screw of Mag switch to the driver (-) as you noted above. I could have put it on any point on the ground ring but the negative leg of the FET is a stronger anchor point and it seems like I get more amps that way. The third wire (other black cable) goes from the back of the FET (opposite side from the legs) to led (-). Positive current to the LED is fed directly off the positive battery terminal on the back of the switch (red wire).
I hope this helps.
Brian
[quote=Bigchelis]
Laughingsorry, but I think I got the information wrong or not clear. Just a last simple question and hope to copy you BTW!!!
_What does the other black cable go to? the Negative on the copper board? (yes), I want to be clear the Negative on copper board goes to Positive on FET Driver right ?_*(no, LED negative goes to the back of the FET (opposite the legs) which is driver negative).
[/quote]
Hi, ok payment done.
Paypal Transaction ID: 40M6767918715450C
Thank you for the detailed explanation. I think I got it now: In summary the top of the FET’s positive is left un soldered to anything.
Correct Bigc,
Now go try it and let me know how it goes!
B
Hello! Maglite received yesterday (rightly packed)! Works greats! Great job! Thank you again Brian!
http://s1.postimg.org/3wdkuqo1b/IMG_1056.jpg
