I normally sell everything through my webstore, but since I'm only doing this one light (for now at least) I thought I'd sell it here.
This light offers a ton of lumens for the size and money. I put a zener modded FET driver in it with off-time memory and copper braided the springs. The thermal path between the two head sections was very poor, with only about 2-3 thin threads worth of connection. I filled the gap with a JB Weld + copper/aluminum powder mix, which drastically improved the thermal conductivity (does not interfere with future modifications or repairs.)
Due to the smaller head and thermal mass, I decided to limit this one down to around 10A-12A with King Kong 26650 cells. This gives around 8000 lumens OTF with fresh cells. This is still a lot of light and on the lower levels the light is very efficient and gives a ton of light and a lot of runtime on the lower levels.
$80 + shipping. PayPal only. Please PM me if you'd like it.
Quick Specs:
3 x 26650 or 18650 (spacers included)
Button top unprotected cells recommended
About 8,000 lumens on startup with good cells (King Kong, 25R, etc.)
5 Mode Levels
Off-Time Memory
Turbo Timer at 45 seconds
Copper braided springs
A few pictures (please see the slightly visible JB weld in the last pictures)
How many cells? The same driver setup (FET driver zener modded) should work fine with 3S cells, although you would then wire the LEDs 3S5P instead of 3S4P like on this light.
4 cells is obviously better for capacity, so I'd try to go that route. You don't quite end up with an even split between the circuits, but you could probably parallel an extra emitter into one of the groups or just leave one out. With 4S cells I might try a 430 ohm resistor on the zener mod instead of the usual 200 ohm to reduce the heat generated there.
Yes. I stripped the stock driver board, then reflowed a 70N02 FET onto it. I then piggybacked a 17mm zener mod FET driver on top to control the FET. You could just piggyback a 17mm zener mod FET on top, but I figured I might as well take advantage of the increased thermal transfer and lower resistance offered by reflowing the FET onto the stock driver.
