MSRP: $270
Sales is as is!
In new-like, mint condition. Only used a few times.
The ThruNite TN36 (including the upgraded TN36 Limited/UT versions) is a compact, high-output “soda-can” style LED flashlight. It pumps out an incredible maximum of 11,000 lumens using three Cree XHP70B LEDs, a multi-battery 18650 carrier design, an orange-peel reflector for massive flood lighting, and a single electronic side switch.
Specifications:
- Max Output: 11,000 lumens (Turbo mode)
- Beam Distance: Up to 353 meters (1,158 feet)
- Peak Beam Intensity: 31,140 cd
- LED Configuration: 3x Cree XHP70 (or older MK-R variants on initial legacy runs)
- Power Source: 4x high-drain 18650 batteries via a removable battery carrier
- Dimensions: Length of 133 mm (5.24 in), head diameter of 64 mm (2.52 in)
- Weight: 427 grams (without batteries)
- Body Material: Aerospace-grade aluminum with Type III hard-anodized finish
- Water resistance: IPX8 rated (submersible up to 1.5 meters)
- User Interface and Modes
Users on CandlePowerForums agree that the single electronic side switch offers a straightforward operation scheme: ON/OFF: Single click the side switch.Firefly: Press and hold from OFF.Ramp / Change Brightness: Press and hold while ON to cycle through infinity high/low levels.Turbo: Double-click from any mode (or from OFF).
Strobe: Double-click while already in Turbo mode.
Performance & Thermal Features:
- Beam Profile: Designed heavily for a floody “wall of light” rather than a tight long-range thrower.
- ITC (Intelligent Temperature Control): Incorporates thermal protection that automatically reduces current if internal temperatures approach 80°C to protect the circuitry.
