I need to reflow some LED’s what type of solder paste is recommended and where should I go to order it?
For just a couple leds you can get by with cheap stuff from fasttech. soldering-paste
I use that cheap stuff too. I mixed it with some liquid flux and put it in a syringe for convenience. Kester solder paste is very good as well. You can get it on ebay.
That cheap paste works GREAT!
I even got a few 3ml syringes from tractor supply and some heavy 16ga needles, took a rotary diamond tool to them…blunt tip…then I simply suck up some paste…gently dab it on the pads…and hit it with a hot air rework gun and voila!
using this one:
http://www.ebay.com/itm/261693237198
works fine, I have nothing to compare it with though
I use this cheap one, works great!
http://www.ebay.com/itm/5pcs-BGA-SMD-Soldering-Paste-Flux-Grease-Volume-10cc-RMA-223-/281358896876?pt=LH_DefaultDomain_0&hash=item41824c0eec
This is flux, not solder paste.
Another vote for the cheap one at FastTech; I've used this stuff a lot and it works great!
http://www.fasttech.com/products/0/10003546/1261003-chips-repair-tool-soldering-paste-grease
I ordered what looks to be the same as the FastTech stuff from a us seller on Ebay because I’m not patient, I have all the pieces for a X6 triple build I just need to reflow the LED’s
Ive put some solder paste between 2 pieces of copper, but it wouldnt stick together. don`t know what I did wrong.. but for me t didnt looks like it worked out very well. solder paste that is.
how do you guys use it? I dont have a hot air gun.
Solder paste works very well on copper.
After you put the solder paste between the copper you need to heat up the surrounding copper until it melts. Heating up just the solder paste isn’t enough.
Also be wary of corrosion on the copper surfaces that you expect to solder together. Hit both surfaces with a bit of sand paper and you’ll have a much easier time “wetting” the pieces with solder/solder paste.
A hot air gun is very handy for any kind of reflow work. It’s too hard to evenly heat the pieces using just a soldering iron tip.
Thanks guys. I remember trying to make a pill of 2 very thin rounds of copper, OL style. But the copper discs didn't stay together.
They were about 40mm, and maybe only about 10mm would actually stick..but nothing more than that. So I stopped.
If you use low-temperature solder paste, you can also melt it by sticking the project in your oven in the kitchen.
Chipquick low temp solder paste sold at Amazon works well.
I don't know about mine. Maybe just the regular type of solder paste.
Will this work for soldering wires to emitters and drivers (sorry if this is a stupid question)?
Nope, you’ll want normal solder for that. I suppose paste could work, but regular solder is easier.
You can use it for that too.
